Q. When should I renew my license contract / date license Expires?
Answer:
Use the following procedure to see when date with which to renew your license (contract expiration date):
1. Open Subscription Service Portal.
2. Click on the "Select" button on the "License Management" tile, and choose "SELECTServer Admin"
3.  When the screen opens, select "License Management", and on the drop down listing choose "View license File"
4. Scan the entire listing while looking at the column labeled "Expires". this is the Date by which the contract should be renewed.
