| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Error |
| Date Logged & Current Version | March. 2018 11.02.00.10 |
The following appears when using AutoPIPE
Intel(r) Visual Fortran run-time error
forrtl: severe (29): file not found, unit 46, file
C:\Users\MIKE~1.DAT\AppData\Local\Temp\AP_110100\503350-P-03 -
choke skid _5006\503350-P-03 - choke skid.pxf
Image PC Routine Line Source
libifcoremd.dll 0F8A91AA Unknown Unknown Unknown
Stack trace terminated abnormally.
OK
Why and how to avoid it?
In this case, there was a space just before the file extension, example:
"There is a space .PXF"
Notice the space after word "space" and before "." of the file extension.
Remove the space in the file name just before the file extension, example:
"There is a space.PXF"
Visual Fortran run-time error messages
