ISO 14692 Piping Code Calculation Issues in AutoPIPE
Note: Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Reference Information> Code Compliance Calculations> select a piping code to see the calculations performed by AutoPIPE.
Comments, Questions, and Answers about ISO 14692 Piping Code Calculation Issues
Item #1: How to calculate the ISO 14692 allowable?
Item 02: Why are the SIF calculations for a Long and Short radius bend exactly the same?
Item 03: What does Vmin mean on the Pipe Properties dialog and Press/Temp/PipeID tab of the input grids in AutoPIPE?
Item 04: Using ISO 14692 and modeling fully restrained piping, does AutoPIPE make the necessary corrections for this condition?
Item 05: How does Actual OD, Corrosion Allow, Mill tol, etc, using in stress calculations?
Piping Code Calculations
