| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | |||
| Date Logged & Current Version |
Jan 2015 09.06.01.10 |
Exactly how is AutoPIPE calculating the combined stress for a node point, equation used and individual values being applied in the equation?
For Tresca stresses, AutoPIPE calculates stress from these three equations and uses the maximum value in subsequent equations:
SL1 = Axial (Neutral axis)
SL2 = Axial + Bending (Max Long if Axial is positive)
SL3 = Axial - Bending
These three values are used to calculate Tresca stresses using:
Similar approach is taken for Von Mises calculation.
