| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | |||
| Date Logged & Current Version | Jan 2015 09.06.01.10 |
The hoop stress uses the D/t ratio to decide which formula to use, thin or thick, However which is being used in combined stress equation, does the D/t ratio still apply for the hoop stress values used in the combined equation?
D/t ratio is used to decide hoop stress formula to be used in combined stress equation. A good discussion on a similar issue is available in our Pipe Stress Analysis Forum which can be accessed by the link below:
http://communities.bentley.com/products/pipe_stress_analysis/f/275801/p/70679/186018.aspx#186018
