Working with Office Files (O365)
ProjectWise Web has a new, enhanced O365 integration workflow.
 Users with O365 Subscription
To Open Office file in O365, select Start Office365 coauthoring from the Open Menu.
This first time you open an Office file with your O365 subscription you will be prompted to log into your Microsoft account.
The file will be marked with people icon in red indicating you have started a co-authoring session. Note that when a user starts a coauthoring session the file is automatically Checked Out. The user who Starts the coauthoring session has to Check-in the file when the session is complete.
 The Document is temporarily saved to the user who started the co-authoring session’s OneDrive.
Other users can join a co-authoring session from the Open Menu. You can tell the document is already open in O365 by the blue people icon on the file.
Using your Office 365 subscription, you can see when multiple users in the file editing:
Remember when all users have done editing the document, the user who Started the coauthoring session must check the document back in. Once the document is checked in, the temporary file in users OneDrive is automatically deleted.
Users without O365 Subscription can access Office Documents with:
