2024.01.80.0
Released 2024-03-05
Enhancements:
- Long Path Handling Improvements: We've made several updates to better handle long file paths, including preventing uploads and reads of files if the path exceeds 256 characters, and improving warning notifications for these instances.
- Windows 11 Context Menu Integration: Our context menu items are now more prominently displayed in Windows 11, making it easier to access PW Drive functions.
- UI Refresh and Front-end Upgrades: We've updated the UI and upgraded front-end dependencies for a fresher look and feel.
Bug Fixes:
- User-Reported Issues: Fixed various bugs impacting AutoCAD integration, file synchronization, and context menu visibility. Notable fixes include:
- Temporary files from AutoCAD and other applications no longer being uploaded to the cloud.
- Issues with automatic file uploads not working until Drive is restarted.
- The problem where files didn't open in desktop applications after being replaced.
- Fixes for issues reported by our users, including icon discrepancies, folder refresh state issues.
- Resolved intermittent file upload failures, crashes related to file renaming, and potential vulnerabilities for a more secure environment.
- WSG and Performance Optimizations: Addressed WSG URL handling, improved database performance through optimized indexes, and reduced unnecessary WSG requests.
- Stability and Data Integrity: Enhanced stability during unsync operations and implemented measures to prevent data loss, including a retry mechanism for auto-check-in and safeguards against opening files when auto-checkout fails. To prevent issues with duplicating folders upon re-sync, Drive aims to not rename root folders if possible.
2023.02.277.0
Released 2023-08-01
- Fixed stability issues with Drive which would result in Drive ‘locking up’
- Prevent data loss when saving Word files when file length exceeds 256 characters
- Prevent duplicates files from being created when editing ArcGIS Pro projects
- Fix PW Web communication issues with Drive when navigating to large folders in PW Web
- Resolved intermittent issues with syncing from PW Drive to the cloud
- Resolved issues when syncing legacy CONNECT projects with PW Drive
- Removed erroneous ‘Failed to download file’ error messages
2023.02.256.0
Released 2023-06-08
- Fixed an issue when upgrading from 2022.01 versions would not keep synchronized projects
- Fixed an issue where manually checked out document status in Drive was displayed incorrectly in Web
2023.02.252.0
Released 2023-05-29
Enhancements:
- Security updates
- Performance: reduced load on WSG server
- Other minor performance optimizations
- Bug fixes
2023.01.101.0 - major release
(this also covers .99, .101)
Released 2023-03-23
Enhancements (from .99.0 version):
- Major performance improvements. Handling of very large projects.
- ProjectWise Office 365 co-authoring
- Get Link function
Bug fixes:
- Security update added to 23.01.100.0, .99.0 deprecated.
- Co-authoring performance improved with .101.0
2022.1.638.0 - update release
Released 2022-07-18
Bug fixes:
- Windows File Explorer stuck on loading folder contents
- Auto-create not working in some cases
- Some files reappear after deleting in Drive
- Sometimes folders that were deleted or renamed reappear
- Auto checkout not working with some PDF review apps
- 'Invalid Device' error on file rename
- Excluded .exe and .dll files from auto upload
- Folder settings changes will be picked up faster
- Drive crashes when PW folder names include certain invalid characters
- Drive Installer fixes
2022.1.328.0 - major release
Released 2022-03-30
Read more here.
Version 2021.3.296.0
Generally Available
Releasd 2021-09-16
Enhancements:
- Removed per user component from Drive installer. This will make enterprise deployments easier.
- Improved usage tracking.
- Bug fixes.
Version 2021.3.282.0 (GA)
Installer improvements.
Version 2021.3.280.0 (GA)
Bug fixes.
Version 2021.3.276.0 - General Availability release
Various bug fixes.
Version 2021.3.268.0 - Public Early Access Release 2021.3
New features:
- Checked out documents anywhere in ProjectWise Work Area Connections or Drive. Document that was checked out via ProjectWise Work Area Connection interface will be always editable via Drive, even if it was checked out when Drive was not running or before user synchronized that project. Also, documents checked out via Drive on one computer will be editable on all other computers with Drive where this user is logged in. Note that changes made locally in one computer will not be automatically moved to another, so users must take precautions to work on a file only in one location.
- Start / Join Office 365 co-authoring using desktop applications. If Drive is installed and running on a computer then co-authing feature will attempt to opens documents using desktop version of Microsoft Office applications. Project does not need to be synchronized in Drive for this to work.
- Installer improvements to work well when Drive is installed with one user and used with a different user.
- Various stability and performance improvements
Bug fixes:
- Fixed issues while editing files/folders via "Save As" dialog in app
- Fixed incorrect "No internet connection" notification
- Fixed issue where Drive could not be installed if a later version of Microsoft Visual C++ redistributable was already installed
Version 2021.2.89.0
Initial public EAP release.
