Note: Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Reference Information> Code Compliance Calculations> select a piping code to see the calculations performed by AutoPIPE.
Comments, Questions, and Answers about DNV piping code calculations in AutoPIPE
Item #1: Is it possible to use edition 1985 to correct calculation or are there important changes in stress calculation between edition 1985 and 2002?
Piping Code Calculations
