Cannot Load .. Cannot access ProjectWise working directory
 Product(s):ProjectWise Web Server
 Version(s):08.11.05.16
 Environment: N\A
 Area: Configurations
 Subarea: N\A
 Original Author:Dana Guthrie, Bentley Technical Support Group
Cannot Load .... Cannot access ProjectWise working directory
When trying to publish or view a dgn via the ProjectWise Webparts WEL
user gets the following error.
Cannot Load http://servername:8087/... Cannot access ProjectWise working directory
In ProjectWise administrator, right click the datasource and choose properties.
On the settings tab scroll to the bottom of the list to the 'web components' section.
for default webserver and default ProjectWise publishing server make sure the FQDN of the server that runs theses services is list with port number if applicable
The port is for the website not the port the publishing service is running on.
Example: http://V8i.bentley.com
Another posibility is if there are two webservers for the same datasource, remove the default webserver entry completly.
