Product(s): | SACS |
Version(s): | 23. |
Area: | Dynamic Response |
I want to execute the time history earthquake analysis in SACS. Simultaneously, I would like to combine the seismic load with seastate load. What is the procedure?
SACS development team has prepared a workflow to combine seismic responses with wave responses for SACS V23.
The basic workflow is:
Now, if you want to combine the seismic load with gravity loads, say dead or live load (mostly for the design purposes), then you can output equivalent static loads for time history earthquake analyses. You can use Seastate with those equivalent static loads or Combine on the solution of those equivalent static loads to create load combinations. This would be another analysis step that you perform on the output OCI file or CSF.
Section 2.2.2.4.1 Load Case Creation in Dynamic Response Manual.
