Authentication Failed. Delegate user is not setup correctly
 Product(s):ProjectWise Web Server
 Version(s):08.11.11.574
 Environment: N/A
 Area: Configurations
 Subarea:
 Original Author:Molly Watts, Bentley Technical Support Group
Error or Warning Message
Explanation
User recieved the error after logging into ProjectWise Web Parts on Sharepoint, with Single Sign On configured, after adding a new web part.  The new web part added was using a datasource that did not have the delegate user configured.
How to Avoid
Option 1- configure the datasource with a delegate user
  1. On the Web Server, go to Start --> Programs --> Bentley --> ProjectWise v8i (SELECTSeries 4) --> Web Server and Web View Server (64-bit) --> ProjectWise Web Server Single SignOn Settings
  2. Select the datasource and enter the delegate user configured per the Implementation guide
 Option 2-modify the web part to use another datasource that is configured with a delegate user
  1. Highlight over the web part arrow and select "Edit Web Part"
2.  Change the Location drop down to the correct datasource
http://communities.bentley.com/products/projectwise/content_management/f/342986/p/5603/9202.aspx#9202
