| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Calculations |
| Date Logged & Current Version | April. 2014 09.06.00.15 |
In the AutoPIPE on line manual (help/contents/code/DNV 2012/ASD) there are references to formulas numbered as per DNV 2010, not as per 2012 edition. At the section 5-F200 of DNV 2012 a new definition of bending is presented, that is not reported in AutoPIPE manual.
Online help shall be updated to reference the correct equation numbers.
First Affected version = 09.06.00.19
Fixed in version = 09.06.01.10 and higher
Logged = TFS-D82926
