Manually Installing/Uninstalling The ProjectWise File Transfer Control FTP Control [TN]
 Product(s):ProjectWise WEL, Web Parts
 Version(s):2004 Edition, XM Edition, V8i
 Environment: N/A
 Area: N/A
 Subarea: N/A
The ProjectWise File Transfer control is an active X installation used by the ProjectWise WEL and WebParts client to download, copy out, or export files. The first time you attempt to checkout, copy out, or download a file, you will be prompted to install this program.
Due to security restrictions it may be necessary to manually install the ProjectWise File Transfer control.
For ProjectWise 2004 Edition and XM Edition
Installation Prerequisites:
Manual Installation:
Note: running regsvr32 with a /s option runs the registration process in silent mode.
Manual Removal:
For ProjectWise V8i
Manual install
Manual Uninstall
For ProjectWise V8i SELECTseries 3
Manual install
When manually installing the ActiveX controls, you need to launch these two installers:
• ProjectWise Web and Web View Servers V8i (SELECTseries 3) ClientComponents.msi — this installs the ProjectWise Web File Transfer ActiveX Control, the VPR ActiveX Control, and the Spatial ActiveX Control
• DgnECViewControlAx.msi— this installs the Bentley DGN ActiveX Control.
These installers are delivered with ProjectWise Server Setups, but are not listed when you launch on the master setup.exe installer. Instead, you will find them in the ...\product\pwwebserver folder.  For example:  C:\BentleyDownloads\pwsrv08110991en\pwwebserver
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
