| Product(s): | ProjectWise Web Explorer Lite | ||
| Version(s): | All | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
ProjectWise Web Explorer Lite has added the ability to add logon credentials to any valid URL. This means that a customer can form a URL that will allow them to display folder contents, document properties or publish a file using Document Publisher or Bentley Publisher.
By default this feature is not enabled. To enable it, modify the web.xml file located in the <installdir>\projectwise\webserver\webapps\WEL\WEB-INF directory.
The user Id and Password are added to the URL or request package for a given document or folder action. In order to add some level of security to the process the password must be base64 encoded. This is the same password encryption that web browsers use for basic authentication. It is further recommend that the customer runs the server in SSL mode (HTTPS).
A typical URL to view a document from Web Explorer Lite looks like:
http://servername/WEL/servlet/LiteServlet?REQUEST_TYPE=VIEW&DSId=datasourceName&VaultId=61&DocId=50
In order to login from another system 3 pieces of information must be added to the URL. The users login id, base64 encoded password and the server name of the server the datasource is published on.
| Item Required | URL Variable | Comment |
| Login Id | Password | Datasource Server Name |
| Id | Pw | DSServer |
| Plain text user login | Base 64 encoded password | Host name of the server in which the DSid datasource is running |
ProjectWise Web Explorer Lite ships with 2 tools to make forming the URLs easier.
<installdir>\projectwise\webserver\webapps\WEL\gfx\styles\base64.js
The URL page generation page is located in <installdir>\projectwise\webserver\webapps\WEL\ WELUrlGen.htm
http://servername/WEL/ WELUrlGen.htm
Please note that the parameter names and values are case sensitive.
The following is a list of request type available.
LiteServlet?REQUEST_TYPE=GetDSList
| Input | &Parameters=refresh |
| Output | Retrieve all registered datasources in the ProjectWise Web Application Server machine |
| Style Sheets | DS.xsl |
| Remarks | None |
LiteServlet?REQUEST_TYPE=LoginScreen
| Input | &DSId=<datasource_name> &DSServer=<pw_app_server_hostname> |
| Output | Show ProjectWise login screen |
| Style Sheets | LoginScreen.xsl |
| Remarks | This screen is not mandatory as users are prompted for login when LiteServlet requests occur without an opened session. |
LiteServlet?REQUEST_TYPE=Logout
| Input | &DSId=<datasource_name> |
| Output | Close user session |
| Style Sheets | LoggedOut.xsl |
| Remarks | None |
LiteServlet?REQUEST_TYPE=GetVaultList
| Input | &DSId=<datasource_name> &VaultId=<vault_id> |
| Output | List sub-vaults for the selected vault |
| Remarks | &vaulted=0 would return all root vaults. |
LiteServlet?REQUEST_TYPE=RemoveVaultList
| Output | Collapse sub-vaults for the selected vault |
| Remarks | &vaulted=0 would collapse all root vaults. |
LiteServlet?REQUEST_TYPE=GetDocList
| Output | Retrieve all documents for the selected vault. |
| Style Sheets | Document.xsl |
| Remarks | Access control applies. Users would only see documents that they have access to. |
LiteServlet?REQUEST_TYPE=Properties
| Input | &DSId=<datasource_name> &VaultId=<vault_id> &DocId=<document_id> |
| Output | Return attributes in "General" sheet. |
| Style Sheets | Properties.xsl |
| Remarks | This shows the "General" sheet in ProjectWise Explorer. |
LiteServlet?REQUEST_TYPE=ShowGeneral
| Style Sheets | Properties_General.xsl |
| Remarks | If LiteServlet?REQUEST_TYPE=Properties is called, you can switch between property page without the above parameters. |
LiteServlet?REQUEST_TYPE=ShowAttributes
| Output | Return attributes in "Attribute" sheet. |
| Style Sheets | Properties_Attributes.xsl |
LiteServlet?REQUEST_TYPE=ShowMoreAttributes
| Output | Return attributes in "More Attributes" sheet. |
| Style Sheets | Properties_MoreAttributes.xsl |
LiteServlet?REQUEST_TYPE=ReferenceFiles
| Input | &DSId=<datasource_name> &Set=<set_id> |
| Output | Return a document list show all the reference files for the selected file. |
| Remarks | LiteServlet?REQUEST_TYPE=ReferenceFiles is also applicable to flatset. |
LiteServlet?REQUEST_TYPE=View
| Output | View the select file using an appropriate viewer defined in global.viewers.properties. |
| Style Sheets | vpr.xsl Bentley Publisher ActiveX viewer Publish.xsl Bentley Publisher Java viewer TextPage.xsl Document Publisher viewer |
| Remarks | If no viewer is associated to the select file type, WEL would perform the action defined in "noviewer.action" in "PWLiteServlet.properties". Default is "copyout". |
LiteServlet?REQUEST_TYPE=CopyOut
| Output | Copy ouy the select file. |
| Style Sheets | Download.xsl |
Queries
LiteServlet?REQUEST_TYPE=OpenSearches
| Input | &DSId=<datasource_name> &QueryId=<query_id> |
| Output | Expand "Searches" list in WEL. |
| Remarks | Use &QueryId=0 for root. |
LiteServlet?REQUEST_TYPE=QueryByForm
| Input | &DSId=<datasource_name> &Environment=<environment_id> |
| Output | Display ProjectWise default search form for the selected environment. |
| Style Sheets | QueryForm.xsl |
| Remarks | None |
http://KMBPWWEB/WEL/servlet/LiteServlet?REQUEST_TYPE=Login&DSId=Kevin_Oracle9i&DSServer=matrix&Id=admin&Pw=YmVudGxleQ==
http://KMBPWWEB/WEL/servlet/LiteServlet?REQUEST_TYPE=View&DSId=Kevin_Oracle9i&DSServer=matrix&Id=admin&Pw=YmVudGxleQ==&VaultId=137&DocId=1
http:// KMBPWWEB\WEL/servlet/LiteServlet?REQUEST_TYPE=Properties&DSId=Kevin_Oracle9i&DSServer=matrix&Id=admin&Pw=YmVudGxleQ==&VaultId=137&DocId=1
http://KMBPWWEB/WEL/servlet/LiteServlet?REQUEST_TYPE=ShowAttributes&DSId=Kevin_Oracle9i&DSServer=matrix&Id=admin&Pw=YmVudGxleQ==&VaultId=137&DocId=1
http://KMBPWWEB/WEL/servlet/LiteServlet?REQUEST_TYPE=CopyOut&DSId=Kevin_Oracle9i&DSServer=matrix&Id=admin&Pw=YmVudGxleQ==&VaultId=137&DocId=1
http://KMBPWWEB/WEL/servlet/LiteServlet?REQUEST_TYPE=OpenSearches&DSId=Kevin_Oracle9i&DSServer=matrix&Id=admin&Pw=YmVudGxleQ==&QueryId=0
ProjectWise TechNotes And FAQs
