Change Authentication method if IMS is not working.
Search Topic /Question:   My users are not able to login to ProjectWise Explorer due to an IMS outage.  How can I get the users working using a different authentication method?
What you will learn: How to change the user account from Federated Identity to Windows.
Product(s):
Version(s):
 All
Area:
 IMS Login
Solution:  In ProjectWise administrator temporarily change the user accounts from Federated Identity to Windows account
Step 1:  Log into ProjectWise Administrator as an administrator
Step 2:  Go to the "Users" node to display all the user accounts.
Step 3:  Click on the "Identity provider" column to sort the user accounts who have an Identity Associated with the account.
Step 4:  High Light all the user accounts that have an Identity.
Step 5:  Right click and choose Properties.
Step 6:  On the General tab under "Security" change the type from "Federated Identity" to "Windows."
Step 7  Click apply \ Okay
Step 8:  Instruct the users to change the login type in ProjectWise Explorer to "Windows Domain"
