Product(s) and Version(s):
Projectwise Design Integration Server: 10.00.03.299
Projectwise Explorer: 10.00.03.299
Problem Description:
In Projectwise Web connections, Right click on a document to display Get link option.
Choose “Get Link” and paste it to your email.
Send the copied link to the project team members to access the document.
When user clicks on the document link, the below options are available to open the link
When choosing Projectwise Explorer as a destination for the link, the file does not open in Projectwise Explorer, and the following error is received. Last Error [112197] Cannot select item. Document version exists but is not in the list.
The document was not available in the document list view because the user was not able to see all versions of the file. This is due to the “show all versions” user setting being unchecked for the user.
Toggled ON the "show all versions" for the users ProjectWise account.
