SACS is an integrated finite element structural analysis package of applications that uniquely provides for the design of offshore structures, including oil and gas platforms, wind farms, and topsides of FPSOs and floating platforms. SACS software has been used by offshore engineers around the world for nearly 40 years. Many of the world's energy companies specify SACS software for use by their engineering firms across the lifecycle of offshore platforms. Because every project has different needs, there are three flexible SACS options. Offshore Structure Ultimate for comprehensive capabilities required for typical offshore jackets, wharfs, and dolphin structures; Offshore Structure Advanced for static topside and deck analysis; and Offshore Structure for static structural analysis.
Jacket Type Structure with Bentley SACS CE (Quick Start Guide)
This playlist has the courses that will guide you through a basic understanding of SACS Jacket Type Structure and Topside Structure in Bentley SACS Connect Edition.
The dataset can be downloaded from here: View Learning Path (bentley.com)
Pre-Services Analysis with Bentley SACS CE
This playlist have the courses you need to understand how to model and perform some pre-services (installation) analysis in Bentley SACS Connect Edition.
In-Service Analyses with Bentley SACS CE
This playlist have the courses you need to understand how to model and perform some In-Services Analyses in SACS Connect Edition.
Advanced Analysis with Bentley SACS CE
This playlist has the courses you need to understand how to perform some advanced analyses in SACS Connect Edition.
