| Product(s): | SACS |
| Version(s): | ALL |
| Area: | Joint Mesh |
Common errors using Joint Mesher
in this post, we will try to list all common errors at the moment to to work with the Joint Mesher tool,
Case 1
Hello Bentley, I have a problem modeling joint meshes I', getting an error message like this
*** ERROR CREATING LOOP 6 OF 12 FOR MEMBER NUMBER 1 (2005-6545)
Joint not meshed successfully
* ERROR - An error occurred during loop decomposition
Can anyone help me with what this problem is caused by?
JointMesher currently works, first creating what we call flattened loops, these loops are basically the points on the boundary of different planes that then get meshed and stitched together to create the mesh, this error means that the software failed to create a loop for a certain surface of that the member mentioned in the error.
If you are facing this issue please don't doubt to create a service case and share your files for our review
