It is suggested to stay within the following limits when using ProjectWise Deliverables Management service.
Operation | Requirements supported for PWDM |
Max package size | 10 GB |
Max number of files in one package | 2000 docs per transmittal (100 docs per 1 folder) |
Max number of references for one file | 461 reference files |
Max depth of nested references | 99 levels |
Max folder depth | 21 level (folder path + file name length should not exceed 255 characters) |
Max PWE projects depth | 11 levels |
Max folder name | 63 characters (PWDI limit) |
Max length of transmittal name | 255 characters |
Max file name | 127 characters (PWDI limit) |
Max number of recipients in one package | 300 recipients |
Max number of related transmittals for one file | 100 transmittals |
Max number of PWDM attributes in a transmittal | 34 (document limit in the package is 450) |
Max number of internal users per single settings synch | 1000 users |
