| Product(s): | SACS |
| Version(s): | 23. |
| Area: | Joint Can |
Can I implement API RP 2A-WSD 22nd Edition clause B.5.3.6.1 for Joint Can check?
Directly, there is no command to include the clause. SACS EQ22 in JCNOPT command caters the full strength of a joint. However, SACS reports both strength and load UC of a joint. So, as a workaround, if you want to check the actual UC ratio of the joint, you can always refer the load UC report.
