| Product(s): | AutoPIPE | ||
| Version(s): | ALL | ||
| Area: | Import | ||
| Date Logged & Current Version | Oct. 2015 10.00.00.10 |
AutoPIPE model of imported PXF file had a missing support or contained only a portion of the model exported from AutoPLANT / OpenPlant, why?
There is an issue in coordinates of "AT_SUPPORT_DUMMY" which was exported by OpenPLANT.
As per AutoPLANT standard, line 3020 value will be duplicate of line 3000, example below:
After making this minor adjustment, the issue will be resolved.
Open CADAP.MAP file (see WIKI here for file location), set 'RETAIN FLANGE LENGTH' = 'N'
Save file, and import PXF file.
Note: If you have a model where some or part of the model is not imported, try upgrading your software, AutoPIPE CONNECT has a few enhancements that addresses these issues over previous versions of the application.
Troubleshooting - Import AutoPlant / OpenPLANT PXF file
417967
