ABS SN curve for Fatigue Analysis in SACS
Product(s):SACS
Version(s):23.00.
Area:Fatigue
Can I use ABS SN Curve for fatigue check in SACS?
If you are looking for ABS - Curve D you may try using ISD - ISO 19902 SN Curve D.
Also, you can define your own curve using line: SN-USR.
Note: To use the SN-USR command user should select AUR option in columns 33-35 of the FTOPT command and replace the "XXX" by the curve ID typed in the SN-USR command.
