Limits for Deflection Ratios
Product(s):Sacs Collapse
Version(s):All
Area:Collapse Solutions
Community Question:
Hello Bentley I'm working using Collapse Advance in a blast/collapse analysis and I need to fulfill the parameter in the  "ASCE Design of Blast-Resistant Buildings in Petrochemical Facilities", so I wondering if is there a way to get  the limit of the deflection in SACS
Answer
