| Product(s): | SACS |
| Version(s): | ALL |
| Area: | Post Solution |
Community Question?
Hello Bentley, I am working on an analysis in which I need to include the card CODE AA to consider the P delta factors, I usually add the card in Datagen, save the model, and close it, but at the moment to open and save using precede this card is removed from my model, could you explain the reason for this?
Answer
If at the moment save your model in precede you come across a similar issue the reason for this is the incompatibility in the card CODE AA thought to work only with AA-WDS AISC 13th/API-RP2A 21st with the code in the model, if you are using AISC version 14th of 15th, is probable that you have this issue problem
AISC 13th Edition code of practice considers two kinds of second-order effects in accordance with section C2.1b as follows.
