| Product(s): | MAXSURF Multiframe |
| Version(s): | 23.07.00.268 |
| Area: | Mesh |
How to resize the patch mesh?
To change the mesh densities of patches
-Double click on the patch in the Frame window or Select a group of patches to be changed in the Frame window.
-Right click and choose Patch Meshing from the pop up menu.
For uniform meshes specify the mesh density along each side of the patch. For non-uniform meshes type in a value for maximum length of a plate side and Multiframe automatically generates all plates for you.
