| Product(s): | AutoPIPE | ||
| Version(s): | ALL | ||
| Area: | Modeling | ||
| Date Logged & Current Version | Feb. 2016 10.00.00.10 |
Why are the Flexible joint symbols different when seen in single line mode in my AutoPIPE model. Does this mean it is a different type of flexible joint? why?
In single line model, the expansion joint is drawn based on the pipe size and length of the joint. For a given pipe size and expansion joint length it may be viewed as either of the following:
The graphic may be different but all 4 represent the same thing, an AutoPIPE Flexible Joint component.
Flexible Joint - Modeling Approaches, Tips, Techniques
