Multiframe - Sections Library Location
Product(s):MAXSURF Multiframe
Version(s):23.07.00.268
Area:Section Library
Where can I locate my previous section library location so that I can load it into the new version?
Go to File menu -- Open Library -- Section Library, and you would see a dialog as below. Click File name drop down, and all used libraries will appear there.
