SESAM to SACS Converter
Question:
How to convert a Sesam input files to SACS?
Answer:
In SACS Executive, under Utilities Menu you will see the SESAM to SACS Converter as shown in the screenshot below:
Drag and drop the .FEM file to ‘Convert Sesam to SACS’ tool and the converter will run and output a new SACS model and a listing file. Please see below:
Note that only the geometry will be converted into SACS. It still needs verification from the user and the loadings need to be reapplied.
