| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Printing |
| Date Logged & Current Version | Dec 2019 12.02.00.14 |
When using Print> Graphics command
The final printout does not show the entire model and everything is out of scale.
How to fix this to print correctly?
The development team has added a new set of commands for users to get the exact image, Tools ribbon> Capture>:
> Screen command enables the user to quickly capture an image of the complete AutoPIPE window.
> Selection command enables the user to quickly capture an image of the components selected in the current AutoPIPE model.
Suggest to use these new updated commands to get exact screen shots of the model for use in your documentation and avoid using the Print Graphics command.
