| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Report | ||
| Date Logged & Current Version | Sept. 2015 09.06.02.06 |
We’re having an issue generating reports for an given AutoPIPE model. For whatever reason when we try and generate these reports, it does not create a cover/title sheet and table of contents he rest of the report is printed fine, just the first 2 pages are missing. why and how to fix it.
File name = 0742 10-12HPS001,3,901,3,10-12CRH001,901(150403).dat
In order to have enough space on the Output report, Max file name length is 48 characters.
Reduce the number of characters in the file-name to 48 or less.
