| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Report | ||
| Date Logged & Current Version | April. 2015 09.06.02.06 |
Printing the AutoPIPE output report, either on paper or PDF, does not fill the entire page, what can be changed so the entire page area is used?
AutoPIPE out reports automatically inserts page breaks for sections that exceed the predetermined page length. AutoPIPE has only one setting that controls the number of lines printed per page. This setting can be found under Tools> Settings> Printer> Lines / Page, as shown below:
This may be an iterative process, increase / decrease this setting as desired, and create a complete output report to include all sub-reports. After creating a complete report. Review the entire output report to be sure of how the modifications affected the printout. Again, this maybe an iterative process.
