| Product(s): | AutoPIPE | ||
| Version(s): | ALL | ||
| Area: | Print/Plot | ||
| Date Logged & Current Version | Feb. 2015 09.06.01.10 |
How to print out / save the AutoPIPE code stress color map?
The Code Stress color map can be exported from AutoPIPE using one of the following methods
1. Run Analyze All command on the current model open in AutoPIPE
2. Select Results> Code Stresses> on this dialog see the "Output Destination" drop down listing (press help button for details):
3. Press OK button to accept the "Output Destination" selection, the result swill be output to that selection made.
4. If "Screen" was selected, the following would have been displayed:
From this point the user could Zoom / Pan the model viewpoint to the correct location and then use typical screen grab techniques to taking a screen image. The screen image can then be pasted into another program as needed.
If "Printer / Plotter" was selected, AutoPIPE will prompt the user to select a valid printer to print the image (hint, using a PDF printer allows the out put image to be combined with other PDFs.
If "File" was selected, AutoPIPE will prompt the user to select a *.PLT file for the output image. The PLT image could then be printed / plotted
If "BMP" was selected, AutoPIPE will prompt the user to select a *.BMP file for the output image.The image file can then be imported into another application as needed.
