| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | |||
| Date Logged & Current Version | Feb. 2015 09.06.01.10 |
When user prints to Adobe PDF from AutoPipe, numbers on drawings appear very tiny. How to make them bigger
The font can be adjusted by using View> Settings> change the TEXT size value to a higher setting:
and press OK button.
