23.00.02 List of Fixed Defects
Collapse Advanced
- 1269368 - Fixed an issue where loads defined past the end of the member would cause Collapse Advanced to crash. A warning message is now generated and the loads which extend past the end of the member are ignored.
- 1275827 - Fixed an issue where Collapse Advanced would not recognize plate elements without an assigned plate group.
Data Generator
- 1308965 - Added grouted option to JSLC line assistant in Datagen for Joint Can analyses.
Fatigue
- 1228695 - Fixed an issue where Fatigue analyses could crash when a plate panel code check option was selected.
Joint Mesher
- 1307914 - Fixed an issue with nominal load transformation in SACS Joint Mesher for SCF extrapolation. Also fixed an issue with Joint Mesher failing to mesh shell elements.
- 1310524 - Fixed an issue with reported stresses for SCF Extrapolation with shell elements and Metric units. Also fixed some minor formatting errors in the SCF Extrapolation report.
Post
- 1259101 - Fixed an issue with Canadian CSA-16 code check where a different design code check might be performed.
Precede
- 1247191 - Fixed an issue with the Load by Volume tool where some elements are not correctly cut below the minimum Z level.
SACS Executive
- 1299936 - Fixed an issue where SACS Offshore Structure Advanced was not used for some Seastate analyses.
- 1314147 - Fixed an issue where the OpenWindPower - Fixed Foundation license required Offshore Select Entitlements.
Seastate
- 1234914 - Fixed an issue where Seastate would not write base shear and overturning moment plots for static transfer function cases.
- 1297096 - Improved Seastate load summation reporting to determine force couples from the relative magnitude of the load about the global axis instead of the total magnitude of the load. This will reduce the number of reported force couples.
Utilities
- 1292650 - Fixed an issue where Rigid would crash if the number of joints exceeded 9999. The upper limit for joints has been increased to 100000.
