| Product(s): | MAXSURF Modeler |
| Version(s): | 23.06.00.137 |
| Area: | Meshing |
How can I create a mesh from an existing surface?
- Select the surfaces
- Go to Meshes | Add from SurfacesÂ
- On the Generate Mesh window, check the boxes next to the surfaces you want to create a trimesh for. Then click okay.
