| Product(s): | MAXSURF Multiframe |
| Version(s): | 23.07.00.268 |
| Area: | Import/Export |
What file formats are possible to import and export?
Multiframe can import and export data to and from other applications using a variety of techniques and data formats. The topology of a frame can be exported to CAD packages via DXF files, images can be pasted into reports via the windows clipboard, data can be copied into spreadsheets or other applications, animations can be saved to file and frame data can be exchanged with other analysis/design or detailing programs via a number of different file format.
File Import:
| Filename extension | |
| .mfd | Multiframe binary |
| .dxf | 2D and 3D DXF |
| .dwg | 2D and 3D DWG |
| .dgn | MicroStation DGN |
| .arc | Microstran archive |
| .txt | Space Gass text |
| SDNF | Steel Detailing Neutral File |
| .struclink | Struclink |
File Export:
| Multiframe binary | |
| .VRML | VRML |
| Bitmap export | Bitmap export |
| ISM | Integrated Structural Modeling |
