Two-way interoperability between SACS and AutoPIPE with change management by using Structural Synchr
Notes:
Featured:
     Technology preview: AutoPIPE CONNECT 12.00.00.14
Overview:
Create or Update a new ISM repository by exporting an analytical piping model. This ISM repository can be later imported or opened in other Bentley ISM-aware applications.
Limitations
Additional Information
Application command can be found under: File > Import/Export > ISM > see commands
Or AutoPIPE Help, see "ISM " user documentation in AutoPIPE help (as shown below).
AutoPIPE Technology Previews
