| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Technology Preview, 624059 |
| Date Logged & Current Version | March. 2017 11.00.00.22 |
AutoPIPE model(s) can now be imported into SACS to provide the piping context and help design of supports and structure. Use the File > Import/Export > Export > SACS SQLITE Database (*.db) command to export the current AutoPIPE model to SACS through SQLite database.
This command checks to verify that appropriate input and output reports are selected before generating the SQLite file that can be imported into SACS.
