Multiframe - Unbraced Length Adjustment
Product(s):MAXSURF Multiframe
Version(s):23.07.00.268
Area:Unbraced Length
How does one adjust the unbraced length on a beam?
- Go to design menu then bending, there you can see the unbraced length
- This does vary a bit depending on the design code used, the Steel Designer Manual explains more, so you may open the Steel Designer manual and then just search for "unbraced" in that document.
Unbraced Length
