| Product(s): | MAXSURF Multiframe |
| Version(s): | 23.07.00.268 |
| Area: | Load Panels |
I have inserted a panel as a panel but want to remove the panel in one location. How do I remove/delete the panel.
There are two options to try:
- Go to the frame window, select the panels (hold CTRL key to do multiple selections) that you wish to remove then press delete on the keyboard.
- You may also go to Select -- Load Panels -- then input load panel numbers (example: 1,2) if you wish to select the two panels on the given sample file below. And then go to Geometry -- Delete Load Panels to remove selected panels.
