| Product(s): | MAXSURFÂ Multiframe |
| Version(s): | |
| Area: | High Resolution Screen |
Users with very high resolution screens are finding that the icons in Multiframe are very small and hard to see.
There are no settings in Multiframe to fix this - however we can instruct Windows to treat the software as DPI Aware. we do this through importing a registry key. One of the great things about this solution is that Windows will adapt per monitor, so you can view the icons at a comfortable size on a high resolution laptop and low resolution external monitor.
The attached file is a text file. Internet security doesn't like *.reg files, so you will need to download it and rename the extension from *.reg.txt to *.reg Make sure that file extensions are visible on your computer.
Once you have changed the file extension, double click to run the file.
