| Product(s): | MAXSURF Stability |
| Version(s): | 23.06.00.137 |
| Area: | Density |
How to set-up custom densities?
Once you have customized the values on the Density Table to use on your projects, load or save it via the File menu (File | Save Densities As).
- Save them to a file (from the file menu) that all the team members can access.
- Import the densities from this common place, and these loaded densities will be saved in the user/computer registry and imported as the default densities each time that user uses Stability on that machine.
