Product(s): | SACS |
Version(s): | All |
Area: | Collapse |
I'm doing a dropped object analysis in SACS collapse. I have successfully run the model and I am getting plasticity results. Is there a way to obtain strain results in addition to the stress/plasticity results?
You can print the plastic strain in the listing file (marked blue in the attached image). Also, you can save maximum plastic strain per subsegment in the Collapse View DB (marked red in the attached image). Then, you can create a report of the plastic strains in Collapse View/Precede. Unfortunately, we can't create plots for the plastic strains at this moment.
