Consider Upheaval Buckling - AutoPIPE Technology Preview
Notes:
Featured:
     Technology preview: AutoPIPE CONNECT 12.00.00.14
Overview:
AutoPIPE supports evaluation of buried pipes for upheaval buckling. When buried pipelines are initially deformed due to manufactured overbends, they are subject to upheaval buckling when axial compressive forces are applied. Upheaval buckling can be significant enough to expose previously buried pipes, exposing them to damage from external elements.
Buckling analysis is performed on any point in the model, however this approach requires an initial vertical overbend, defined through the coordinate geometry of the buried pipeline system. In other words, buckling will only occur at points where compressive forces push the pipe upward. Thermal and pressure loading causes these points to push upward and buckle. Should this overbend result in a vertical deflection, the Soil output report will provide additional soil depth required to prevent vertical deflection. The Soil output report will then provide soil depth to be removed. For example, if the current soil depth is 60 inches, and the Soil output report recommends 6 inches, increasing the soil depth to 66 inches is expected to reduce upheaval buckling to the allowed vertical deflection.
AutoPIPE uses the following theory by K. Peters.
Limitations
Additional Information
See "Upheaval Buckling Technology Preview" user documentation in AutoPIPE help (as shown below).
AutoPIPE Technology Previews
