Export to Multiframe Structure
Product(s):MAXSURF Modeler
Version(s):23.07.00.268
Area:Export Surface
The function export mesh file from Maxsurf modeler to the Multiframe not available.
Can you advise if my version can support that?
There is no problem exporting mesh to Multiframe with this version.
Just make sure that you have a meshed surface when exporting mesh to Multiframe to activate this function.
Wiki: Add Mesh from Surfaces
