| Product(s): | SACS |
| Version(s): | ALL. |
| Area: | Fatigue |
Community Question:
how to change the SCF for a specific Joint connection?
AnswerÂ
The user can specify an SCF value used to override any value either calculated by the program or
specified as a default value using the SCF and SCF2 lines
Beam element values can be overridden for specific joints, member groups, individual members, or
specific brace-chord connections. The hierarchy of SCF overrides is as follows:
