| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Calculation |
| Date Logged & Current Version | April. 2018 11.02.00.10 |
In a model where the pipe and elbow have a different pipe ID that includes different wall thickness. As shown below:
The SIF and stress were calculated to:
In an effort to reduce the code stress on the elbow, a 2.34 user SIF with override SIF option enabled was added to the elbow:
However now the stress are calculated as:
how is it possible to apply the user SIFs(2.34 only to override SIF=2.92) in AutoPipe models for bends without affecting the default SIF(1.00) value at A15N- and A15+?
This a limitation of the programs ability to apply the user SIF to the node point. Currently, AutoPIPE V8i 09.06.xx.xx and lower applies the user SIF to both the +ve and -ve side of a node point. A new enhancement (TFS-E79346: Add option to apply an SIF to one or both sides of a node point) has been logged to apply the USER SIF value a specific side / face (i.e. +ve and /or -ve) of a node point .
SIF values in Code Compliance report
