06. SIF values in Code Compliance report of AutoPIPE
Comments, Questions, and Answers with SIF calculations in AutoPIPE
What is the equation used for SIF calculation:
If the model is not corrupted, properly modeled, and no override user SIF defined, AutoPIPE should be using the equation mentioned in AutoPIPE Help Code compliance calculations. Please see the following AutoPIPE help section: Help ribbon> Contents button> Contents Tab> Reference Information> Code Compliance Calculations> select Piping Code> Year> Flexibility and SIF document.
