| Version(s): | 2004, XM, & V8i | ||
| Area: | Analysis | ||
Sept 2013, AutoPIPE V8i 09.06.00.15
Why are my V-stops not allowing lateral movement during a Hydrotest load case in AutoPIPE ?
From AutoPIPE online help:
Hydrotest Non-linear Method
To enable hydrotest with gaps and friction, check the 'Non-linear' option for hydrotest load set in analysis sets dialog.
A non-linear static analysis cannot be performed on the hydrotest load case i.e. friction, support gaps and soil yielding are ignored.
