04. AutoPIPE command - Rotate
FAQ about AutoPIPE Rotate command
Item #1:
What is the procedure to rotate all or a potion of an AutoPIPE model?
Item #2:
What, if any, are known issues or limitations with rotating piping?
Item #3:
What changes where added in the Rotate command in version 09.06 and higher?
Item #4:
What axis should the pipe be rotated about: X-axis, Y-axis, or Z-axis when using Rotate command?
Item #5:
How to print the "Component Rotation"report?
Item #6:
Right click Pan-Zoom-Rotate command does not function correctly
Cut / Copy / Paste / Rotate / Move / Stretch Commands
